World Dryer Airforce J4-973A3 Air Filter Replacement
  1. World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: step 1, image 1 of 3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: step 1, image 2 of 3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: step 1, image 3 of 3
    • In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Air Filter Replacement: step 2, image 1 of 3 World Dryer Airforce J4-973A3 Air Filter Replacement: step 2, image 2 of 3 World Dryer Airforce J4-973A3 Air Filter Replacement: step 2, image 3 of 3
    • To access both filters, unscrew all three 1/2" Ph2 screws.
    • Gently pull the plate away from the black, coarse filter.
  3. World Dryer Airforce J4-973A3 Air Filter Replacement: step 3, image 1 of 2 World Dryer Airforce J4-973A3 Air Filter Replacement: step 3, image 2 of 2
    • After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
    • We recommend either vacuuming the filters or washing them to remove the dust that has accumulated on the filter.
    • Leave the filters out to dry for 24 hours before putting it back into use, in order to avoid water damage or electric shock!
Blane Hirsh
260 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 232
