Withings Smart Body Analyzer Motherboard Replacement
  1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: step 1, image 1 of 1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Motherboard Replacement: step 2, image 1 of 3 Withings Smart Body Analyzer Motherboard Replacement: step 2, image 2 of 3 Withings Smart Body Analyzer Motherboard Replacement: step 2, image 3 of 3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Motherboard Replacement: step 3, image 1 of 2 Withings Smart Body Analyzer Motherboard Replacement: step 3, image 2 of 2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: step 4, image 1 of 2 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
  5. Withings Smart Body Analyzer Motherboard Replacement: step 5, image 1 of 1
    • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
  6. Withings Smart Body Analyzer Motherboard Replacement: step 6, image 1 of 1
    • Once the two screws and the ribbon cable are detached, remove the motherboard.
3 other people completed this guide.
Ashley Dauphinee
317 Reputation
2 Guides authored
2 Comments
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - Reply
where do you get the motherboard?
cost?
donald taylor - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 39
All Time: 4,916
