Whirlpool WED87HED Dryer Steam Nozzle Replacement
  1. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Safety Precautions: step 1, image 1 of 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the top panel: step 2, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the top panel: step 2, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the top panel: step 2, image 3 of 3
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the top panel: step 3, image 1 of 2 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the top panel: step 3, image 2 of 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 4, image 1 of 2 Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 4, image 2 of 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the cover plate: step 5, image 1 of 1
    • Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
  6. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cover plate: step 6, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cover plate: step 6, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cover plate: step 6, image 3 of 3
    • Remove the cover plate.
  7. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the cord: step 7, image 1 of 1
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    • Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
    • If your plug has 4 prongs, there will be a ground connection from the cord as well. Use a 5/16 inch nut driver to remove this connection.
  8. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cord: step 8, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cord: step 8, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cord: step 8, image 3 of 3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the cord terminal block: step 9, image 1 of 1
    • Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
    • Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
  10. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Move the cord terminal block: step 10, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Move the cord terminal block: step 10, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Move the cord terminal block: step 10, image 3 of 3
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the rear panel: step 11, image 1 of 2 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the rear panel: step 11, image 2 of 2
    FixMat
    $36.95
    Buy
    • Use a 1/4 inch nut driver to remove the eleven rear panel screws.
    • Ten 20 mm-long screws
    • One 12.9 mm-long screw under the water inlet.
  12. Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 12, image 1 of 2 Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 12, image 2 of 2
    • Use a 1/4 inch nut driver to remove the 16.4 mm-length screw holding the main board bracket to the chassis.
    • Use a 1/4 inch nut driver to remove the two 20 mm-long screws from the top rear of the machine.
  13. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the rear panel: step 13, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the rear panel: step 13, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the rear panel: step 13, image 3 of 3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Reassembly information: step 14, image 1 of 2 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Reassembly information: step 14, image 2 of 2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the water tube: step 15, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the water tube: step 15, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the water tube: step 15, image 3 of 3
    • Push the retaining clip out with a small screwdriver or spudger.
    • Grab the retaining clip with your fingertips and remove it.
  16. Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 16, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 16, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement: step 16, image 3 of 3
    • Press the yellow sleeve toward the valve to release the water tube.
    • While holding the sleeve in place, pull the water tube out of the sleeve
  17. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the nozzle cover: step 17, image 1 of 1
    • Use a 1/4 inch nut driver to remove the 12.9 mm‑long sheet metal screw securing the steam nozzle cover.
    • Be careful not to drop any tools as you work, or you may chip the drum's enamel coating
  18. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the nozzle cover: step 18, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the nozzle cover: step 18, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the nozzle cover: step 18, image 3 of 3
    • Lift the lower edge of the cover and tilt it outward to clear the nozzle.
    • Slide the cover down to disengage the tab at the upper end of the cover.
    • Remove the cover.
  19. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten nozzle assembly: step 19, image 1 of 1
    • Use a 1/4 inch nut driver to remove the 12.9 mm-long nozzle assembly screw.
  20. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove nozzle assembly: step 20, image 1 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove nozzle assembly: step 20, image 2 of 3 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove nozzle assembly: step 20, image 3 of 3
    • Lift the nozzle assembly up to disengage the tab at the lower end.
    • Remove the nozzle assembly.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
