Whirlpool WED87HED Dryer Power Cord Replacement
  1. Whirlpool WED87HED Dryer Power Cord Replacement, Safety Precautions: step 1, image 1 of 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Power Cord Replacement, Unfasten the cover plate: step 2, image 1 of 1
    • Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
  3. Whirlpool WED87HED Dryer Power Cord Replacement, Remove the cover plate: step 3, image 1 of 3 Whirlpool WED87HED Dryer Power Cord Replacement, Remove the cover plate: step 3, image 2 of 3 Whirlpool WED87HED Dryer Power Cord Replacement, Remove the cover plate: step 3, image 3 of 3
    • Remove the cover plate.
  4. Whirlpool WED87HED Dryer Power Cord Replacement, Disconnect the cord: step 4, image 1 of 1
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    • Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
    • If your plug has 4 prongs, there will be a ground connection from the cord as well. Use a 5/16 inch nut driver to remove this connection.
  5. Whirlpool WED87HED Dryer Power Cord Replacement, Remove the cord: step 5, image 1 of 3 Whirlpool WED87HED Dryer Power Cord Replacement, Remove the cord: step 5, image 2 of 3 Whirlpool WED87HED Dryer Power Cord Replacement, Remove the cord: step 5, image 3 of 3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 168
