Whirlpool WED87HED Dryer Main Board Replacement
  1. Whirlpool WED87HED Dryer Main Board Replacement, Safety Precautions: step 1, image 1 of 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Main Board Replacement, Unfasten the top panel: step 2, image 1 of 3 Whirlpool WED87HED Dryer Main Board Replacement, Unfasten the top panel: step 2, image 2 of 3 Whirlpool WED87HED Dryer Main Board Replacement, Unfasten the top panel: step 2, image 3 of 3
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Main Board Replacement, Remove the top panel: step 3, image 1 of 2 Whirlpool WED87HED Dryer Main Board Replacement, Remove the top panel: step 3, image 2 of 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Main Board Replacement: step 4, image 1 of 2 Whirlpool WED87HED Dryer Main Board Replacement: step 4, image 2 of 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Main Board Replacement, Disconnect the Main Board: step 5, image 1 of 2 Whirlpool WED87HED Dryer Main Board Replacement, Disconnect the Main Board: step 5, image 2 of 2
    • Disconnect all the wires from the main board.
  6. Whirlpool WED87HED Dryer Main Board Replacement: step 6, image 1 of 3 Whirlpool WED87HED Dryer Main Board Replacement: step 6, image 2 of 3 Whirlpool WED87HED Dryer Main Board Replacement: step 6, image 3 of 3
    • Continue disconnecting the main board.
  7. Whirlpool WED87HED Dryer Main Board Replacement: step 7, image 1 of 3 Whirlpool WED87HED Dryer Main Board Replacement: step 7, image 2 of 3 Whirlpool WED87HED Dryer Main Board Replacement: step 7, image 3 of 3
    • Finish disconnecting the wires from the main board.
  8. Whirlpool WED87HED Dryer Main Board Replacement, Remove the main board cover: step 8, image 1 of 3 Whirlpool WED87HED Dryer Main Board Replacement, Remove the main board cover: step 8, image 2 of 3 Whirlpool WED87HED Dryer Main Board Replacement, Remove the main board cover: step 8, image 3 of 3
    • Using a flat head screwdriver or a spudger, release the cover clips.
  9. Whirlpool WED87HED Dryer Main Board Replacement: step 9, image 1 of 3 Whirlpool WED87HED Dryer Main Board Replacement: step 9, image 2 of 3 Whirlpool WED87HED Dryer Main Board Replacement: step 9, image 3 of 3
    • Lift the cover to release the tabs on the opposite side of the main board housing.
    • Remove the cover.
  10. Whirlpool WED87HED Dryer Main Board Replacement, Release the main board: step 10, image 1 of 3 Whirlpool WED87HED Dryer Main Board Replacement, Release the main board: step 10, image 2 of 3 Whirlpool WED87HED Dryer Main Board Replacement, Release the main board: step 10, image 3 of 3
    Anti-Static Wrist Strap
    $7.95
    Buy
    • There are six retaining clips securing the main board. Start at one end and work towards the other.
    • When you're handling the main board, wear an anti-static strap if possible, or regularly touch the exposed metal parts of the dryer to prevent electrostatic damage to the board.
    • Lift the board with one hand and use the other to release each clip with a spudger.
    • As you go, keep a gentle upward pull on the board so that the released clips don't snap back into place as you work.
    • Alternate sides of the board when releasing the clips.
  11. Whirlpool WED87HED Dryer Main Board Replacement: step 11, image 1 of 2 Whirlpool WED87HED Dryer Main Board Replacement: step 11, image 2 of 2
    • Release the remaining clips until the board is completely separated from its housing.
  12. Whirlpool WED87HED Dryer Main Board Replacement, Remove the main board: step 12, image 1 of 1
    • Remove the main board from its housing.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,362 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 92
