Wexford CT-166TF Air Filter Casing Replacement
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: step 1, image 1 of 1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: step 2, image 1 of 3 Wexford CT-166TF Air Filter Casing Replacement: step 2, image 2 of 3 Wexford CT-166TF Air Filter Casing Replacement: step 2, image 3 of 3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: step 3, image 1 of 1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: step 4, image 1 of 2 Wexford CT-166TF Air Filter Casing Replacement: step 4, image 2 of 2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: step 5, image 1 of 2 Wexford CT-166TF Air Filter Casing Replacement: step 5, image 2 of 2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: step 6, image 1 of 1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: step 7, image 1 of 2 Wexford CT-166TF Air Filter Casing Replacement: step 7, image 2 of 2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: step 8, image 1 of 2 Wexford CT-166TF Air Filter Casing Replacement: step 8, image 2 of 2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: step 9, image 1 of 1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: step 10, image 1 of 2 Wexford CT-166TF Air Filter Casing Replacement: step 10, image 2 of 2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Dannis Thompson
261 Reputation
2 Guides authored
UW Tacoma, Team S3-G4, Liner Spring 2017 Member of UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 609
