Wacom Intuos Pro Motherboard Replacement
  1. Wacom Intuos Pro Motherboard Replacement, Battery: step 1, image 1 of 3 Wacom Intuos Pro Motherboard Replacement, Battery: step 1, image 2 of 3 Wacom Intuos Pro Motherboard Replacement, Battery: step 1, image 3 of 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Motherboard Replacement: step 2, image 1 of 3 Wacom Intuos Pro Motherboard Replacement: step 2, image 2 of 3 Wacom Intuos Pro Motherboard Replacement: step 2, image 3 of 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Motherboard Replacement: step 3, image 1 of 2 Wacom Intuos Pro Motherboard Replacement: step 3, image 2 of 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Motherboard Replacement: step 4, image 1 of 2 Wacom Intuos Pro Motherboard Replacement: step 4, image 2 of 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Motherboard Replacement: step 5, image 1 of 2 Wacom Intuos Pro Motherboard Replacement: step 5, image 2 of 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
  6. Wacom Intuos Pro Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
  7. Wacom Intuos Pro Motherboard Replacement: step 7, image 1 of 1
    • Remove the 4.5mm screw holding down the motherboard using a Phillips #00 screwdriver.
  8. Wacom Intuos Pro Motherboard Replacement: step 8, image 1 of 1
    • Remove all three ribbon cables by gently pulling on their respective ''Black" and "Blue" tabs.
  9. Wacom Intuos Pro Motherboard Replacement: step 9, image 1 of 1
    • Gently remove the motherboard from the case.
0 Comments
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,173
