WRS315SDHW Door Seal Replacement
  1. WRS315SDHW Door Seal Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Door Seal Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Door Seal Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Door Seal Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Door Seal Replacement, Disconnect the door seal: step 3, image 1 of 3 WRS315SDHW Door Seal Replacement, Disconnect the door seal: step 3, image 2 of 3 WRS315SDHW Door Seal Replacement, Disconnect the door seal: step 3, image 3 of 3
    • Insert an opening tool, or a similar tool, between the door frame and the seal.
    • Pry up to separate the seal from its groove on the frame.
    • This may take significant force.
  4. WRS315SDHW Door Seal Replacement, Remove the door seal: step 4, image 1 of 3 WRS315SDHW Door Seal Replacement, Remove the door seal: step 4, image 2 of 3 WRS315SDHW Door Seal Replacement, Remove the door seal: step 4, image 3 of 3
    • Use your hand and the opening tool to peel the door seal away from the frame.
    • Repeat this process for the perimeter of the door seal until the seal is completely separated.
  5. WRS315SDHW Door Seal Replacement, Only the door seal remains: step 5, image 1 of 3 WRS315SDHW Door Seal Replacement, Only the door seal remains: step 5, image 2 of 3 WRS315SDHW Door Seal Replacement, Only the door seal remains: step 5, image 3 of 3
    • You're now left with the door seal.
    • During reassembly, perform the following:
    • Use a Jimmy, or a similar tool, to remove any sealing foam in the door frame groove.
    • Use a mild cleaning solution to fully clean the groove.
    • Reinstall your door by attaching the top edge first, then wrapping the seal around the frame's perimeter.
    • You'll hear the gasket lock into the seam.
    • You may have to stretch the seal a few inches at the final edge.
  6. WRS315SDHW Door Seal Replacement, Perform a seal test: step 6, image 1 of 3 WRS315SDHW Door Seal Replacement, Perform a seal test: step 6, image 2 of 3 WRS315SDHW Door Seal Replacement, Perform a seal test: step 6, image 3 of 3
    • To test if your replacement door seal is working, perform the following:
    • Open the door slightly and insert a clean, flat bill between the door seal and the frame.
    • Close the door and slowly drag the bill away from the device.
    • If the seal is tight, then you should feel a moderate amount of resistance in the bill.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
584 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 68
