Hold the on/off button for 3 seconds until the screen is black.
Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
Turn camera upside down to allow the batteries to fall out.
There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
Using a Phillips #00 screwdriver, remove the 5 (3.5mm in length) screws shown to the left.
Remember to place small screws on magnetic mat or in a container.
Using a pry tool or fingernail, gently pry the circuit board from the base.
Gently lift the lower right hand corner of the circuit board, separating it from the base.
Locate LCD and gently bend it back to reveal ribbon cable connector.
Using small screw driver or tweezers gently slide the edges of the ribbon lock towards the direction of the cable.
Once the lock is opened, use tweezers to slide the ribbon cable from the connector.
Replace LCD as needed and repeat steps in reverse to reassemble.
