Vivotek FD8169 Motherboard Replacement
  1. Vivotek FD8169 Motherboard Replacement, Dome Cover: step 1, image 1 of 1
    • Loosen the outside screw.
  2. Vivotek FD8169 Motherboard Replacement: step 2, image 1 of 1
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Motherboard Replacement, Camera Module: step 3, image 1 of 1
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Motherboard Replacement: step 4, image 1 of 1
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Motherboard Replacement: step 5, image 1 of 1
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Motherboard Replacement: step 6, image 1 of 1
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Motherboard Replacement: step 7, image 1 of 1
    • Pull the camera out from the camera base.
  8. Vivotek FD8169 Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
  9. Vivotek FD8169 Motherboard Replacement: step 9, image 1 of 1
    • Once the screws are gone, lift the faulty motherboard and replace with a new one.
Artem Dudko
135 Reputation
1 Guide authored
UMass Dartmouth, Team 1-6, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-6, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G6
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 259
