Visual Land Prestige 7G Speaker Replacement
  1. Visual Land Prestige 7G Speaker Replacement, Backplate: step 1, image 1 of 2 Visual Land Prestige 7G Speaker Replacement, Backplate: step 1, image 2 of 2
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Speaker Replacement: step 2, image 1 of 1
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Speaker Replacement: step 3, image 1 of 2 Visual Land Prestige 7G Speaker Replacement: step 3, image 2 of 2
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Speaker Replacement, Speaker: step 4, image 1 of 2 Visual Land Prestige 7G Speaker Replacement, Speaker: step 4, image 2 of 2
    • Take the soldering gun and place it on the black and red wires to melt the soldered conncetions.
    • Remove the speaker.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 31
