Visual Land Prestige 7G Battery Replacement
  1. Visual Land Prestige 7G Battery Replacement, Backplate: step 1, image 1 of 2 Visual Land Prestige 7G Battery Replacement, Backplate: step 1, image 2 of 2
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Battery Replacement: step 2, image 1 of 1
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Battery Replacement: step 3, image 1 of 2 Visual Land Prestige 7G Battery Replacement: step 3, image 2 of 2
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Battery Replacement, Battery: step 4, image 1 of 3 Visual Land Prestige 7G Battery Replacement, Battery: step 4, image 2 of 3 Visual Land Prestige 7G Battery Replacement, Battery: step 4, image 3 of 3
    • Use an opening tool to lift the battery from the device.
    • Be careful to not use a metal spudger or tool, as it can bend and harm the battery.
  5. Visual Land Prestige 7G Battery Replacement: step 5, image 1 of 2 Visual Land Prestige 7G Battery Replacement: step 5, image 2 of 2
    • Take your soldering gun and carefully remove the red and black wire connecting the battery to the motherboard.
For optimal performance, calibrate your newly installed battery after completing this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 58
