Verizon Ellipsis 8 Speaker Replacement
  1. Verizon Ellipsis 8 Speaker Replacement, Battery: step 1, image 1 of 1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Speaker Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Speaker Replacement: step 3, image 1 of 1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Speaker Replacement: step 4, image 1 of 1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Speaker Replacement, Speaker: step 5, image 1 of 3 Verizon Ellipsis 8 Speaker Replacement, Speaker: step 5, image 2 of 3 Verizon Ellipsis 8 Speaker Replacement, Speaker: step 5, image 3 of 3
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
Attached Documents
Sreedhar Kesari
190 Reputation
2 Guides authored
IUPUI, Team S2-G2, Stella Fall 2019 Member of IUPUI, Team S2-G2, Stella Fall 2019
IUPUI-STELLA-F19S2G2
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 232
