Verizon Ellipsis 8 Battery Replacement
  1. Verizon Ellipsis 8 Battery Replacement, Battery: step 1, image 1 of 1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Battery Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Battery Replacement: step 3, image 1 of 1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Battery Replacement: step 4, image 1 of 1
    • Lift and remove the battery from the device.
7 other people completed this guide.
Jack
589 Reputation
3 Guides authored
UC Davis, Team S18-G6, Lore Winter 2019 Member of UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 Members
3 Guides authored
3 Comments
Thanks! Easy to follow because of the pictures.
Siegfried Harrison Ph.D. - Reply
These instructions do not apply to the Verizon Ellipsis 8, QTASUN1. The G3 LTE unit requires that you remove the top end that covers the camera lens by popping the edge fasteners along the seam across the back with the spudger, carefully and then sliding the end (that covers the camera lens) off the top of the tablet. At that point three tiny Allen screws will become exposed. Remove the tiny screws and put them on a piece of tape! Make sure the micro memory card and sim card are removed! Using the spudger ( or a very thin knife edge) pop the bottom covering snaps backwards until you can slide the back downward to expose the battery. At that point it is the same as the description for battery replacement. Be very careful about loosing the three tiny, tiny, tainy flat head allen screws that hold the back on the tablet. Take your time and be methodical. If an 80 year old can do it, so can you!
James V Redding - Reply
Can you tell me what size the screws are that hold in the battery, I know that the thread size is 0.1 mm but I have been trying to find replacement screws and can't find them anywhere so I have to custom order them and need more information on them? Any assistance you could give me would be greatly appreciated. jwooten_el@yahoo.com
James Wooten - Reply
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 74
All Time: 9,922
