Verizon Ellipsis 8 Antenna Replacement
  1. Verizon Ellipsis 8 Antenna Replacement, Battery: step 1, image 1 of 1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Antenna Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Antenna Replacement: step 3, image 1 of 1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Antenna Replacement: step 4, image 1 of 1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Antenna Replacement, Antenna: step 5, image 1 of 1
    • Using a plastic opening tool, lift the motherboard along the top right edge of the device.
  6. Verizon Ellipsis 8 Antenna Replacement: step 6, image 1 of 3 Verizon Ellipsis 8 Antenna Replacement: step 6, image 2 of 3 Verizon Ellipsis 8 Antenna Replacement: step 6, image 3 of 3
    • Once you have access to the antenna, remove it and replace it.
Jack
589 Reputation
3 Guides authored
UC Davis, Team S18-G6, Lore Winter 2019 Member of UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 259
