VTech VM3254 Monitor Circuit Board and Screen Replacement
  1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: step 1, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: step 1, image 2 of 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 2, image 1 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 2, image 2 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 2, image 3 of 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 3, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 3, image 2 of 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 4, image 1 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 4, image 2 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 4, image 3 of 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
  5. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: step 5, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: step 5, image 2 of 2
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 6, image 1 of 1
    • Desolder the wire connecting the speaker to the board.
  7. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: step 7, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: step 7, image 2 of 2
    • Remove the three 8 mm Phillips #00 screws.
    • Gently remove the screen and circuit board from the case.
  8. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 8, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 8, image 2 of 2
    • Remove the button assembly from the front of the screen unit.
    • Flip the screen unit back over and desolder the wire holding it to the case.
Christina Block
375 Reputation
4 Guides authored
One Comment
Any source for replacement screens?
Rob Olivieri - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 44
All Time: 732
