VTech VM3254 Camera Speaker Replacement
  1. VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: step 1, image 1 of 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: step 1, image 2 of 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: step 1, image 3 of 3
    • Remove the two 8 mm Phillips #00 screws from the back of the device.
    • Use the Jimmy tool to open the case.
    • You may need to use an opening pick to hold it open.
    • Remove the face from the case.
  2. VTech VM3254 Camera Speaker Replacement: step 2, image 1 of 2 VTech VM3254 Camera Speaker Replacement: step 2, image 2 of 2
    • Remove the three 8 mm Phillips #00 screws from the board.
    • Gently remove the board from the case.
    • Be careful, there are wires connecting the board to the case that could be damaged.
  3. VTech VM3254 Camera Speaker Replacement, Camera Speaker: step 3, image 1 of 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: step 3, image 2 of 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: step 3, image 3 of 3
    • Unscrew and remove the two 7 mm Phillips #0 screws that secure the speaker.
    • Remove the speaker.
    • Desolder the speakers cords from the motherboard.
Christina Block
375 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 168
