VTech Baby's Learning Laptop Volume Switch Replacement
  1. VTech Baby's Learning Laptop Volume Switch  Replacement, Battery and Rear Panel: step 1, image 1 of 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Volume Switch  Replacement: step 2, image 1 of 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Volume Switch  Replacement: step 3, image 1 of 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Volume Switch  Replacement: step 4, image 1 of 2 VTech Baby's Learning Laptop Volume Switch  Replacement: step 4, image 2 of 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Volume Switch  Replacement, Volume Switch: step 5, image 1 of 1
    • Flip your device so the bottom panel is facing up.
  6. VTech Baby's Learning Laptop Volume Switch  Replacement: step 6, image 1 of 2 VTech Baby's Learning Laptop Volume Switch  Replacement: step 6, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
  7. VTech Baby's Learning Laptop Volume Switch  Replacement: step 7, image 1 of 2 VTech Baby's Learning Laptop Volume Switch  Replacement: step 7, image 2 of 2
    • Remove the volume switch.
    • Be careful not damage the wiring.
Jordan Smith
210 Reputation
2 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2015 Member of USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 700
