Unfasten Battery
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Unfasten Battery, Unfasten the display cable bracket: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the display cable bracket:
    • Four 1.1 mm-long screws
    • One 2.0 mm-long screw
  2. Unfasten Battery, Remove the display cable bracket: step 2, image 1 of 2 Unfasten Battery, Remove the display cable bracket: step 2, image 2 of 2
    • Use tweezers, or your fingers, to remove the display cable bracket.
  3. Unfasten Battery, Disconnect the SIM card reader: step 3, image 1 of 2 Unfasten Battery, Disconnect the SIM card reader: step 3, image 2 of 2
    • Use a spudger to pry up and disconnect the SIM card reader cable press connector.
  4. Unfasten Battery, Reposition the SIM card reader cable: step 4, image 1 of 2 Unfasten Battery, Reposition the SIM card reader cable: step 4, image 2 of 2
    • The SIM card reader cable is lightly adhered to the battery.
    • Use tweezers, or your fingers, to peel the SIM card reader cable away from the battery connector.
  5. Unfasten Battery, Unfasten the battery connector: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the 1.7 mm-long screw securing the battery connector to the logic board.
  6. Unfasten Battery, Disconnect the top display cables: step 6, image 1 of 3 Unfasten Battery, Disconnect the top display cables: step 6, image 2 of 3 Unfasten Battery, Disconnect the top display cables: step 6, image 3 of 3
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  7. Unfasten Battery, Disconnect the bottom display cables: step 7, image 1 of 3 Unfasten Battery, Disconnect the bottom display cables: step 7, image 2 of 3 Unfasten Battery, Disconnect the bottom display cables: step 7, image 3 of 3
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  8. Unfasten Battery, Remove the screen: step 8, image 1 of 3 Unfasten Battery, Remove the screen: step 8, image 2 of 3 Unfasten Battery, Remove the screen: step 8, image 3 of 3
    • Remove the screen.
Alex Diaz-Kokaisl
124,298 Reputation
581 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,207 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4
