Umbrella Stretcher to Rib Joint Repair
  1. Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: step 1, image 1 of 2 Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: step 1, image 2 of 2
    • Take the broken part of the stretcher to rib joint.
    • Realign it with the rib assembly.
  2. Umbrella Stretcher to Rib Joint Repair: step 2, image 1 of 1
    • Take the needle and carefully pass it through one of the holes as seen in the picture.
    • Then pull it back to the same side you went through.
  3. Umbrella Stretcher to Rib Joint Repair: step 3, image 1 of 1
    • Take the needle and pass it under the stretcher (not through the middle).
  4. Umbrella Stretcher to Rib Joint Repair: step 4, image 1 of 1
    • Position the needle so that it faces the second hole from the same side you just went through in step 3.
    • Take the needle and pass it through the second hole.
    • Then position the needle so that it faces the first hole from the same side you just went through.
  5. Umbrella Stretcher to Rib Joint Repair: step 5, image 1 of 2 Umbrella Stretcher to Rib Joint Repair: step 5, image 2 of 2
    • Repeat steps 2-4 until the two pieces are held tightly together.
    • Tie a knot to secure it.
    • Refer to step six if the rib punctured the canopy.
  6. Umbrella Stretcher to Rib Joint Repair: step 6, image 1 of 2 Umbrella Stretcher to Rib Joint Repair: step 6, image 2 of 2
    • It is easier to sew when the canopy is closed
    • Take the hole, hold each end and pull outward into a line.
    • Make sure that it is in line with the umbrella canopy seam.
    • Take the needle and thread and form a hemming stitch (see Step 7).
  7. Umbrella Stretcher to Rib Joint Repair: step 7, image 1 of 3 Umbrella Stretcher to Rib Joint Repair: step 7, image 2 of 3 Umbrella Stretcher to Rib Joint Repair: step 7, image 3 of 3
    • Begin with a threaded needle and start the stitch at one end of the hole and pull the needle all the way until just before the thread runs out.
    • Then loop back around and go through again.
    • Repeat until you reach the other end.
    • You can form the stitch multiple times to make it more secure.
The umbrella is fixed now, you may now use the umbrella freely.
2 other people completed this guide.
Rodrigo Soliva
182 Reputation
1 Guide authored
2 Comments
I have a problem with the auto lock, it's a knight bridge umbrella, when i retract it, it doesn't lock in place, can it be fixed or replace the handle in case it's totally eroded?
kamec 01 - Reply
I have 2 umbrellas which have both snapped at the hole. Is there a way this technique or a version of it can be used to repair them?
Jenny - Reply
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 205
All Time: 11,641
