Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement
  1. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: step 1, image 1 of 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: step 1, image 2 of 2
    • Remove the Torx-head screws (23.2mm) on the inside panel of the tailgate, using the torx T25 screwdriver.
  2. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 2, image 1 of 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 2, image 2 of 2
    • Pull off the panel and then pull cables inward, causing tailgate to release and go down.
  3. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 3, image 1 of 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 3, image 2 of 2
    • Remove rubber pieces from cable and pull cable from insert.
  4. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 4, image 1 of 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 4, image 2 of 2
    • Use your 5/16th-in. wrench to turn bolt counter clockwise and remove the bolts (18.5mm).
  5. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 5, image 1 of 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 5, image 2 of 2
    • Push in black clip to let handle fall out.
  6. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 6, image 1 of 1
    • Put new tailgate handle back in.
  7. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 7, image 1 of 1
    • Hand twist in bolts; then tighten with wrench.
  8. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 8, image 1 of 1
    • Insert cable back into socket and press rubber lock onto cable.
  9. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: step 9, image 1 of 1
    • Put panel back into place and screw in using your torx -T25 screwdriver.
This Device is a medium hardness fix but, with hard-work it can be achieved in only about 30 minutes
Brandon Gibson
169 Reputation
1 Guide authored
2 Comments
You skipped the problematic part about changing the lock.
Declan Haptism - Reply
I’m about to replace my handle.. I also need the 4 white clips that help align the latch rods. Mine were old brittle and all broken. Any chance you have a part number for those small clips?
Ryan Rodriguez - Reply
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 171
All Time: 10,032
