Toyota Corolla 2018 Brake Light Replacement
  1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: step 1, image 1 of 2 Toyota Corolla 2018 Brake Light Replacement, Brake Light: step 1, image 2 of 2
    • Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
  2. Toyota Corolla 2018 Brake Light Replacement: step 2, image 1 of 2 Toyota Corolla 2018 Brake Light Replacement: step 2, image 2 of 2
    • Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
    • The rear turn signal bulb is located at the top and has a grey cap.
    • The brake light is located at the bottom and has an orange cap.
  3. Toyota Corolla 2018 Brake Light Replacement: step 3, image 1 of 2 Toyota Corolla 2018 Brake Light Replacement: step 3, image 2 of 2
    • Turn the brake light counterclockwise and pull the old light straight out of the socket.
  4. Toyota Corolla 2018 Brake Light Replacement: step 4, image 1 of 1
    • Replace the new bulb and push it in the socket.
  5. Toyota Corolla 2018 Brake Light Replacement: step 5, image 1 of 1
    • Turn the socket clockwise while placing it in the housing.
  6. Toyota Corolla 2018 Brake Light Replacement: step 6, image 1 of 2 Toyota Corolla 2018 Brake Light Replacement: step 6, image 2 of 2
    • Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
Finish Line
2 other people completed this guide.
Nishanth Selvarajah
187 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 91
All Time: 3,803
