Toshiba Thrive Charging Port Replacement
  1. Toshiba Thrive Charging Port Replacement, Back Cover: step 1, image 1 of 1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Charging Port Replacement: step 2, image 1 of 2 Toshiba Thrive Charging Port Replacement: step 2, image 2 of 2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Charging Port Replacement: step 3, image 1 of 1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Charging Port Replacement: step 4, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 4, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 4, image 3 of 3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Charging Port Replacement, Midframe: step 5, image 1 of 2 Toshiba Thrive Charging Port Replacement, Midframe: step 5, image 2 of 2
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Charging Port Replacement: step 6, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 6, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 6, image 3 of 3
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Charging Port Replacement: step 7, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 7, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 7, image 3 of 3
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Charging Port Replacement: step 8, image 1 of 2 Toshiba Thrive Charging Port Replacement: step 8, image 2 of 2
    • Carefully open the device like a book and lay the two halves beside each other.
  9. Toshiba Thrive Charging Port Replacement, Charging Port: step 9, image 1 of 3 Toshiba Thrive Charging Port Replacement, Charging Port: step 9, image 2 of 3 Toshiba Thrive Charging Port Replacement, Charging Port: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two screws holding the charging port in place. The screws are 3mm in length and require a PH0 screwdriver.
    • Using a pair of tweezers, lift up the charging port's protective covering
  10. Toshiba Thrive Charging Port Replacement: step 10, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 10, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 10, image 3 of 3
    • Use the tweezers to pull out the connector connecting the charging port to the motherboard.
    • Using the tweezers again, gently lift up the charging port from your Thrive.
7 other people completed this guide.
Kason
1,120 Reputation
5 Guides authored
USF Tampa, Team 10-1, Brown Fall 2014 Member of USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Members
12 Guides authored
One Comment
I added "better pictures" flag because i was having trouble following the last step cause i couldnt see anything.
Sun Fai Lau - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 4,057
