Toshiba Thrive Battery Replacement
  1. Toshiba Thrive Battery Replacement, Back Cover: step 1, image 1 of 1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Battery Replacement: step 2, image 1 of 2 Toshiba Thrive Battery Replacement: step 2, image 2 of 2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Battery Replacement: step 3, image 1 of 1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Battery Replacement: step 4, image 1 of 3 Toshiba Thrive Battery Replacement: step 4, image 2 of 3 Toshiba Thrive Battery Replacement: step 4, image 3 of 3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
7 other people completed this guide.
Kason
1,120 Reputation
5 Guides authored
USF Tampa, Team 10-1, Brown Fall 2014 Member of USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Members
12 Guides authored
One Comment
You should give links on where we can buy the parts that need to be replaced.
Meggie Guerrer - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,303
