Toshiba Tecra 8200 Hard Drive Replacement
  1. Toshiba Tecra 8200 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 Hard Drive Replacement: step 2, image 1 of 3 Toshiba Tecra 8200 Hard Drive Replacement: step 2, image 2 of 3 Toshiba Tecra 8200 Hard Drive Replacement: step 2, image 3 of 3
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Locate the hard drive panel.
    • Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
    • Save the screw, as it will be needed for reassembly.
    • Remove the panel, exposing the hard drive.
  4. Toshiba Tecra 8200 Hard Drive Replacement: step 4, image 1 of 2 Toshiba Tecra 8200 Hard Drive Replacement: step 4, image 2 of 2
    • Pull the tab to remove the hard drive.
    • Insert the new hard drive by pushing it into the compartment, leaving the new "pull" tab exposed.
  5. Toshiba Tecra 8200 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Tecra 8200 Hard Drive Replacement: step 5, image 2 of 2
    • Tuck the "pull" tab back into the hard drive compartment.
    • Replace the panel.
    • Replace the single F4 screw.
  6. Toshiba Tecra 8200 Hard Drive Replacement: step 6, image 1 of 3 Toshiba Tecra 8200 Hard Drive Replacement: step 6, image 2 of 3 Toshiba Tecra 8200 Hard Drive Replacement: step 6, image 3 of 3
    • Identify the connector pins on the battery.
    • Line up the connector pins on the battery with the connector pins on the computer and push inward to reconnect the battery.
    • Slide the exterior panel towards the center of the computer to lock the battery in place.
Finish Line
Sally
306 Reputation
3 Guides authored
Ohio State, Team 1-3, Buehl Winter 2015 Member of Ohio State, Team 1-3, Buehl Winter 2015
OSU-BUEHL-W15S1G3
3 Members
9 Guides authored
One Comment
Awesome Thanks!
Erin Dulac - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,239
