Toshiba Satellite p875 s7200 RAM Stick Replacement
  1. Toshiba Satellite p875 s7200 RAM Stick Replacement, RAM Stick: step 1, image 1 of 1
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 RAM Stick Replacement: step 2, image 1 of 1
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 RAM Stick Replacement: step 3, image 1 of 1
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Toshiba Satellite p875 s7200 RAM Stick Replacement: step 4, image 1 of 1
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
Danny Amado
823 Reputation
5 Guides authored
Baylor, Team S1-G3, Williams Fall 2018 Member of Baylor, Team S1-G3, Williams Fall 2018
BU-WILLIAMS-F18S1G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 356
