Toshiba Satellite e205 Keyboard Replacement
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite e205 Keyboard Replacement, Battery: step 1, image 2 of 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: step 3, image 1 of 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: step 4, image 1 of 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
2 other people completed this guide.
Tyler
4,920 Reputation
16 Guides authored
TechForce Member of TechForce
Business
2 Members
25 Guides authored
2 Comments
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Reply
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 657
