Toshiba Satellite e205 Bottom Cover Replacement
  1. Toshiba Satellite e205 Bottom Cover Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite e205 Bottom Cover Replacement, Battery: step 1, image 2 of 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Bottom Cover Replacement, Keyboard: step 2, image 1 of 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Bottom Cover Replacement: step 3, image 1 of 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Bottom Cover Replacement: step 4, image 1 of 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Bottom Cover Replacement, Bottom Cover: step 5, image 1 of 1
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Bottom Cover Replacement: step 6, image 1 of 1
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Bottom Cover Replacement: step 7, image 1 of 1
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Bottom Cover Replacement: step 8, image 1 of 2 Toshiba Satellite e205 Bottom Cover Replacement: step 8, image 2 of 2
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Bottom Cover Replacement: step 9, image 1 of 2 Toshiba Satellite e205 Bottom Cover Replacement: step 9, image 2 of 2
    • Remove the two screews.
  10. Toshiba Satellite e205 Bottom Cover Replacement: step 10, image 1 of 1
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Bottom Cover Replacement: step 11, image 1 of 1
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Bottom Cover Replacement: step 12, image 1 of 1
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
Tyler
4,920 Reputation
16 Guides authored
TechForce Member of TechForce
Business
2 Members
25 Guides authored
One Comment
Step 11 is missing the step of removing the wire from the white pin just above the nuvoTon chip (black in color) this is located when moving diagonally left from the black wireless antenna lead (green circle) and the top left red circle containing one of the black screws. All descriptions of direction are based on the picture used in step 11.
Devin Olson - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 799
