Toshiba Satellite c650d RAM Replacement
  1. Toshiba Satellite c650d RAM Replacement, Battery: step 1, image 1 of 1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d RAM Replacement: step 2, image 1 of 1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d RAM Replacement: step 3, image 1 of 2 Toshiba Satellite c650d RAM Replacement: step 3, image 2 of 2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d RAM Replacement, RAM: step 4, image 1 of 1
    • Remove the one 5.5mm Philips #0 screw that holds in the central panel.
  5. Toshiba Satellite c650d RAM Replacement: step 5, image 1 of 1
    • Pull the back panel off.
  6. Toshiba Satellite c650d RAM Replacement: step 6, image 1 of 1
    • Remove the RAM.
    • Carefully undo the clips on either side of the top RAM.
    • Remove the chip by pulling it out of its slot.
    • Repeat until you have removed the chip that you want to replace.
    • This laptop has only two slots for RAM, and both are filled. Plan accordingly if your goal is to increase RAM.
Brenna Callahan
868 Reputation
5 Guides authored
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 664
