Toshiba Satellite c650d Fan Replacement
  1. Toshiba Satellite c650d Fan Replacement, Battery: step 1, image 1 of 1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Fan Replacement: step 2, image 1 of 1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Fan Replacement: step 3, image 1 of 2 Toshiba Satellite c650d Fan Replacement: step 3, image 2 of 2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Fan Replacement, Keyboard: step 4, image 1 of 1
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Fan Replacement: step 5, image 1 of 1
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Fan Replacement: step 6, image 1 of 1
    • Detach the ribbon cable that connects the keyboard to the motherboard.
  7. Toshiba Satellite c650d Fan Replacement, Fan: step 7, image 1 of 1
    • Detach the cable connecting the fan to the motherboard.
  8. Toshiba Satellite c650d Fan Replacement: step 8, image 1 of 2 Toshiba Satellite c650d Fan Replacement: step 8, image 2 of 2
    • Remove the one 3.0mm and one 5.0mm Philips #0 screws holding the fan in place.
  9. Toshiba Satellite c650d Fan Replacement: step 9, image 1 of 1
    • Remove the fan by pulling it out slowly.
4 other people completed this guide.
Brenna Callahan
868 Reputation
5 Guides authored
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,422
