Toshiba Satellite U925T-S2120 RAM Replacement
  1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: step 1, image 1 of 2 Toshiba Satellite U925T-S2120 RAM Replacement, RAM: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the 9 rubber gripper pads on the back panel of the laptop using tweezers.
  2. Toshiba Satellite U925T-S2120 RAM Replacement: step 2, image 1 of 3 Toshiba Satellite U925T-S2120 RAM Replacement: step 2, image 2 of 3 Toshiba Satellite U925T-S2120 RAM Replacement: step 2, image 3 of 3
    • Unscrew nine 5.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
    • Unscrew two 6.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
  3. Toshiba Satellite U925T-S2120 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite U925T-S2120 RAM Replacement: step 3, image 2 of 2
    • Take off the back panel open by sticking the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 RAM Replacement: step 4, image 1 of 2 Toshiba Satellite U925T-S2120 RAM Replacement: step 4, image 2 of 2
    • Gently pinch the RAM with your thumb and pointer finger.
    • Pull the RAM out of the logic board with gentle force.
    • Try to keep the RAM parallel as you pull it out, so that the RAM does not chip.
2 other people completed this guide.
Andrew Honderich
364 Reputation
3 Guides authored
Baylor, Team S5-G5, Williams Spring 2017 Member of Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 552
