Toshiba Satellite U925T-S2120 Fan Replacement
  1. Toshiba Satellite U925T-S2120 Fan Replacement, Fan: step 1, image 1 of 2 Toshiba Satellite U925T-S2120 Fan Replacement, Fan: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the 9 rubber grip pads on the back panel of the laptop.
  2. Toshiba Satellite U925T-S2120 Fan Replacement: step 2, image 1 of 3 Toshiba Satellite U925T-S2120 Fan Replacement: step 2, image 2 of 3 Toshiba Satellite U925T-S2120 Fan Replacement: step 2, image 3 of 3
    • Use a PH1 screwdriver to remove the nine 5.8 mm screws.
    • Unscrew the two 6.8 mm screws. Set all screws aside.
  3. Toshiba Satellite U925T-S2120 Fan Replacement: step 3, image 1 of 2 Toshiba Satellite U925T-S2120 Fan Replacement: step 3, image 2 of 2
    • Remove the back panel by inserting the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 Fan Replacement: step 4, image 1 of 1
    • Unscrew the two 5.4 mm screws with a PH1 screwdriver.
  5. Toshiba Satellite U925T-S2120 Fan Replacement: step 5, image 1 of 3 Toshiba Satellite U925T-S2120 Fan Replacement: step 5, image 2 of 3 Toshiba Satellite U925T-S2120 Fan Replacement: step 5, image 3 of 3
    • Pull the cables away from the two connectors in the same direction as the individual wires are running.
  6. Toshiba Satellite U925T-S2120 Fan Replacement: step 6, image 1 of 1
    • Gently use you thumb and forefinger to lift and remove the fan.
Andrew Honderich
364 Reputation
3 Guides authored
Baylor, Team S5-G5, Williams Spring 2017 Member of Baylor, Team S5-G5, Williams Spring 2017
BU-WILLIAMS-S17S5G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 397
