Toshiba Satellite U840W Disassembly Guide
  1. Toshiba Satellite U840W Disassembly Guide, Toshiba Satellite U840W Disassembly Guide: step 1, image 1 of 2 Toshiba Satellite U840W Disassembly Guide, Toshiba Satellite U840W Disassembly Guide: step 1, image 2 of 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Disassembly Guide: step 2, image 1 of 3 Toshiba Satellite U840W Disassembly Guide: step 2, image 2 of 3 Toshiba Satellite U840W Disassembly Guide: step 2, image 3 of 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Disassembly Guide: step 3, image 1 of 3 Toshiba Satellite U840W Disassembly Guide: step 3, image 2 of 3 Toshiba Satellite U840W Disassembly Guide: step 3, image 3 of 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Disassembly Guide: step 4, image 1 of 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
2 other people completed this guide.
Eric
261 Reputation
2 Guides authored
Gateway, Team S1-G1, Saknee Spring 2019 Member of Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 976
