Toshiba Satellite U405D-S2902 Hard Drive Replacement
  1. Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
    • The screws can not be removed from the panel, so loosen them until the panel can come off.
    • Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
  2. Toshiba Satellite U405D-S2902 Hard Drive Replacement: step 2, image 1 of 1
    • After lifting the cover up carefully, slide it to the left to be removed.
  3. Toshiba Satellite U405D-S2902 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite U405D-S2902 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite U405D-S2902 Hard Drive Replacement: step 3, image 3 of 3
    • Place two fingers gently on the hard drive.
    • Slide it back to the left.
    • Lift the drive by the two corner tabs making sure not to touch the metel
    • Do not press down too hard on the top of the drive, or you will damage it. Only use enough pressure to be able to remove it from the SATA connection.
2 other people completed this guide.
Brandon Kirklen
311 Reputation
8 Guides authored
Cal Poly, Team 7-8, Maness Winter 2013 Member of Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 505
