Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement
  1. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 2, image 1 of 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 2, image 2 of 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 3, image 1 of 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 3, image 2 of 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: step 4, image 1 of 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: step 4, image 2 of 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 5, image 1 of 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 5, image 2 of 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 6, image 1 of 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: step 6, image 2 of 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: step 7, image 1 of 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: step 7, image 2 of 2
    • Carefully slide the optical disk drive to the right to remove from the motherboard.
Nicholas Costa
321 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 318
