Toshiba Satellite S55t-A5389 RAM Replacement
  1. Toshiba Satellite S55t-A5389 RAM Replacement, RAM: step 1, image 1 of 1
    • Unscrew the single Phillips #0 screw from the RAM panel.
  2. Toshiba Satellite S55t-A5389 RAM Replacement: step 2, image 1 of 1
    • Remove the panel.
  3. Toshiba Satellite S55t-A5389 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite S55t-A5389 RAM Replacement: step 3, image 2 of 2
    • Spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
  4. Toshiba Satellite S55t-A5389 RAM Replacement: step 4, image 1 of 2 Toshiba Satellite S55t-A5389 RAM Replacement: step 4, image 2 of 2
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
When installing the new RAM, push the RAM sticks in at an angle. Proceed to push each RAM stick down until the latches click, indicating that it is locked in.
2 other people completed this guide.
William Mazanec
1,350 Reputation
8 Guides authored
USF Tampa, Team S5-G6, Passmore Spring 2018 Member of USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 399
