Toshiba Satellite S55t-A5389 Processor Replacement
  1. Toshiba Satellite S55t-A5389 Processor Replacement, Battery: step 1, image 1 of 1
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Processor Replacement: step 2, image 1 of 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Processor Replacement: step 3, image 1 of 3 Toshiba Satellite S55t-A5389 Processor Replacement: step 3, image 2 of 3 Toshiba Satellite S55t-A5389 Processor Replacement: step 3, image 3 of 3
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Processor Replacement, Processor Fan: step 4, image 1 of 1
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Toshiba Satellite S55t-A5389 Processor Replacement: step 5, image 1 of 1
    • Disconnect the fan from the motherboard.
  6. Toshiba Satellite S55t-A5389 Processor Replacement: step 6, image 1 of 1
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Toshiba Satellite S55t-A5389 Processor Replacement, Processor: step 7, image 1 of 1
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Toshiba Satellite S55t-A5389 Processor Replacement: step 8, image 1 of 1
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
2 other people completed this guide.
William Mazanec
1,350 Reputation
8 Guides authored
USF Tampa, Team S5-G6, Passmore Spring 2018 Member of USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Members
8 Guides authored
One Comment
Can i use i7 4940mx cpu on this laptop
Movies Star - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 646
