Toshiba Satellite S55t-A5389 Keyboard Replacement
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite S55t-A5389 Keyboard Replacement: step 2, image 2 of 2
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: step 3, image 1 of 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: step 3, image 2 of 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: step 3, image 3 of 3
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
3 other people completed this guide.
William Mazanec
1,350 Reputation
8 Guides authored
USF Tampa, Team S5-G6, Passmore Spring 2018 Member of USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 593
