Toshiba Satellite Radius P55W-B5220 RAM Replacement
  1. Toshiba Satellite Radius P55W-B5220 RAM Replacement, Back Cover: step 1, image 1 of 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 RAM Replacement: step 2, image 1 of 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 RAM Replacement: step 3, image 1 of 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 RAM Replacement: step 4, image 1 of 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: step 5, image 1 of 2 Toshiba Satellite Radius P55W-B5220 RAM Replacement, RAM: step 5, image 2 of 2
    • Push outward on the clamps holding the RAM in place.
  6. Toshiba Satellite Radius P55W-B5220 RAM Replacement: step 6, image 1 of 1
    • Remove the RAM chips.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 636
