Toshiba Satellite Radius P55W-B5220 Back Cover Replacement
  1. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: step 2, image 1 of 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: step 3, image 1 of 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: step 4, image 1 of 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
2 other people completed this guide.
One Comment
Can you show replace this model display, and please please, give de part number of the screen
Erick Ramon Garibay Valencia - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,283
