Toshiba Satellite R15-S829 Keyboard Replacement
  1. Toshiba Satellite R15-S829 Keyboard Replacement, Battery Replacement: step 1, image 1 of 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Keyboard Replacement: step 2, image 1 of 3 Toshiba Satellite R15-S829 Keyboard Replacement: step 2, image 2 of 3 Toshiba Satellite R15-S829 Keyboard Replacement: step 2, image 3 of 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite R15-S829 Keyboard Replacement, Keyboard Replacement: step 3, image 2 of 2
    • First, begin by removing the plastic cover that is located at the top of the keyboard. This can be pried off or just removed by hand by grabbing the plastic piece by the indent on either side and lifting up.
    • Be careful to avoid breaking the plastic.
  4. Toshiba Satellite R15-S829 Keyboard Replacement: step 4, image 1 of 1
    • Locate the two screws on each side.
  5. Toshiba Satellite R15-S829 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite R15-S829 Keyboard Replacement: step 5, image 2 of 2
    • Remove the two screws with a phillips head screwdriver. Be careful not to lose the screws.
  6. Toshiba Satellite R15-S829 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite R15-S829 Keyboard Replacement: step 6, image 2 of 2
    • Lift the keyboard up to reveal the power plug.
  7. Toshiba Satellite R15-S829 Keyboard Replacement: step 7, image 1 of 2 Toshiba Satellite R15-S829 Keyboard Replacement: step 7, image 2 of 2
    • Disconnect the keyboard from the laptop by unplugging the power ribbon.
Mike Strother
299 Reputation
2 Guides authored
UMass Dartmouth, Team 5-8, Martin Fall 2016 Member of UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 10
All Time: 189
