Toshiba Satellite R15-S829 Hard Drive Replacement
  1. Toshiba Satellite R15-S829 Hard Drive Replacement, Battery Replacement: step 1, image 1 of 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Hard Drive Replacement: step 2, image 1 of 3 Toshiba Satellite R15-S829 Hard Drive Replacement: step 2, image 2 of 3 Toshiba Satellite R15-S829 Hard Drive Replacement: step 2, image 3 of 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Hard Drive Replacement, Hard Drive Replacement: step 3, image 1 of 1
    • First, begin by locating the spot of the cover of the hard drive located on the bottom of the laptop.
  4. Toshiba Satellite R15-S829 Hard Drive Replacement: step 4, image 1 of 1
    • Remove the screw of the cover.
  5. Toshiba Satellite R15-S829 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite R15-S829 Hard Drive Replacement: step 5, image 2 of 2
    • Locate the indent where the hard drive can be removed. Remove the cover.
  6. Toshiba Satellite R15-S829 Hard Drive Replacement: step 6, image 1 of 2 Toshiba Satellite R15-S829 Hard Drive Replacement: step 6, image 2 of 2
    • Remove the hard drive using your hand.
  7. Toshiba Satellite R15-S829 Hard Drive Replacement: step 7, image 1 of 3 Toshiba Satellite R15-S829 Hard Drive Replacement: step 7, image 2 of 3 Toshiba Satellite R15-S829 Hard Drive Replacement: step 7, image 3 of 3
    • Now remove the power ribbon from the hard drive.
  8. Toshiba Satellite R15-S829 Hard Drive Replacement: step 8, image 1 of 1
    • Locate the screws on each side of the encasing of the hard drive.
  9. Toshiba Satellite R15-S829 Hard Drive Replacement: step 9, image 1 of 2 Toshiba Satellite R15-S829 Hard Drive Replacement: step 9, image 2 of 2
    • Use your Phillips screwdriver to remove the screws and be careful not to lose the screws.
  10. Toshiba Satellite R15-S829 Hard Drive Replacement: step 10, image 1 of 1
    • Remove the encasing from the hard drive.
Mike Strother
299 Reputation
2 Guides authored
UMass Dartmouth, Team 5-8, Martin Fall 2016 Member of UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 417
