Toshiba Satellite R15-S829 Disk Drive Replacement
  1. Toshiba Satellite R15-S829 Disk Drive Replacement, Battery Replacement: step 1, image 1 of 1
    • Unplug the charging cable from the laptop.
    • Turn off the laptop.
    • Turn the laptop over and locate the battery.
  2. Toshiba Satellite R15-S829 Disk Drive Replacement: step 2, image 1 of 3 Toshiba Satellite R15-S829 Disk Drive Replacement: step 2, image 2 of 3 Toshiba Satellite R15-S829 Disk Drive Replacement: step 2, image 3 of 3
    • Push the small switch near the corner of the laptop to the unlocked position.
    • Push the bigger switch in the direction of the icon and pull the battery away from the laptop.
  3. Toshiba Satellite R15-S829 Disk Drive Replacement, Disk Drive Replacement: step 3, image 1 of 2 Toshiba Satellite R15-S829 Disk Drive Replacement, Disk Drive Replacement: step 3, image 2 of 2
    • Locate the disk drive on the side of the laptop.
  4. Toshiba Satellite R15-S829 Disk Drive Replacement: step 4, image 1 of 1
    • Locate the indent on disk drive on the backside of the computer.
  5. Toshiba Satellite R15-S829 Disk Drive Replacement: step 5, image 1 of 2 Toshiba Satellite R15-S829 Disk Drive Replacement: step 5, image 2 of 2
    • Use your hand to remove the disk drive by pulling outward.
  6. Toshiba Satellite R15-S829 Disk Drive Replacement: step 6, image 1 of 3 Toshiba Satellite R15-S829 Disk Drive Replacement: step 6, image 2 of 3 Toshiba Satellite R15-S829 Disk Drive Replacement: step 6, image 3 of 3
    • Push the end of a paperclip into the small hole on the disk drive to open it if there is a disk that is stuck in the drive.
Justin Slater
128 Reputation
3 Guides authored
UMass Dartmouth, Team 5-8, Martin Fall 2016 Member of UMass Dartmouth, Team 5-8, Martin Fall 2016
UMASSD-MARTIN-F16S5G8
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 133
