Toshiba Satellite P855-S5312 Keyboard Replacement
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: step 2, image 1 of 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: step 2, image 2 of 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: step 2, image 3 of 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
215 Reputation
2 Guides authored
USF Tampa, Team S10-G2, Thompson Fall 2017 Member of USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,209
