Toshiba Satellite P855-S5102 RAM Replacement
  1. Toshiba Satellite P855-S5102 RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite P855-S5102 RAM Replacement, Battery: step 1, image 2 of 2
    • Push the locking tabs away from each other.
  2. Toshiba Satellite P855-S5102 RAM Replacement: step 2, image 1 of 2 Toshiba Satellite P855-S5102 RAM Replacement: step 2, image 2 of 2
    • Pull up on the battery to remove.
  3. Toshiba Satellite P855-S5102 RAM Replacement, RAM: step 3, image 1 of 2 Toshiba Satellite P855-S5102 RAM Replacement, RAM: step 3, image 2 of 2
    • Remove the 3mm Phillips #0 screw from the cover.
  4. Toshiba Satellite P855-S5102 RAM Replacement: step 4, image 1 of 3 Toshiba Satellite P855-S5102 RAM Replacement: step 4, image 2 of 3 Toshiba Satellite P855-S5102 RAM Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to lift up the cover and remove by hand.
  5. Toshiba Satellite P855-S5102 RAM Replacement: step 5, image 1 of 3 Toshiba Satellite P855-S5102 RAM Replacement: step 5, image 2 of 3 Toshiba Satellite P855-S5102 RAM Replacement: step 5, image 3 of 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out.
Benson Smith
351 Reputation
3 Guides authored
USF Tampa, Team S20-G3, Passmore Spring 2018 Member of USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 332
