Toshiba Satellite P855-S5102 Laptop Screen Replacement
  1. Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: step 1, image 1 of 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: step 1, image 2 of 2
    • Remove the two F3 screws on the bottom part of the screen.
  2. Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 2, image 1 of 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, carefully pry open the border of the screen away from the screen until the border is completely off.
  3. Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 3, image 1 of 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 3, image 2 of 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 3, image 3 of 3
    • Using the Phillips 001, carefully remove each F3 screw on each corner of the screen.
  4. Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 4, image 1 of 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 4, image 2 of 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 4, image 3 of 3
    • Using the Phillips 012, remove the three F2 screws on each side of the screen.
  5. Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 5, image 1 of 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 5, image 2 of 2
    • Carefully lift up the screen for an easier removal of the webcam. Then gently remove the connector by sliding it out of the webcam.
  6. Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 6, image 1 of 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement: step 6, image 2 of 2
    • Remove the tape holding the sliding connector and gently pull it out.
Rodrigo
133 Reputation
1 Guide authored
USF Tampa, Team S20-G3, Passmore Spring 2018 Member of USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 12
All Time: 265
