Toshiba Satellite P855-S5102 Keyboard Replacement
  1. Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Use a plastic opening tool to pry up the keyboard cover.
  2. Toshiba Satellite P855-S5102 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite P855-S5102 Keyboard Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry up the keyboard.
  3. Toshiba Satellite P855-S5102 Keyboard Replacement: step 3, image 1 of 3 Toshiba Satellite P855-S5102 Keyboard Replacement: step 3, image 2 of 3 Toshiba Satellite P855-S5102 Keyboard Replacement: step 3, image 3 of 3
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
Benson Smith
351 Reputation
3 Guides authored
USF Tampa, Team S20-G3, Passmore Spring 2018 Member of USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 Members
7 Guides authored
One Comment
Proceeding this way you will get to break all seals that join that “cover“ to the rest of the keyboard assembly, rendering it unusable if you were not replacing it (in the “step 2“ photos you get to see all the broken pins where the joined parts used to be). In fact, you have to proceed from the other side and remove the cover from under the computer, there you’ll find some small tabs towards the touchpad end of things, you gently pry each tab while loosening that side of the keyboard and it rises up. Be careful not to break the flex circuit that joins it to the mainboard in the process.
Kenneth - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 414
