Toshiba Satellite P755 S5390 Touchpad Repair
  1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: step 1, image 1 of 3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: step 1, image 2 of 3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: step 1, image 3 of 3
    • Make sure that your laptop is powered off before starting.
    • Close the cover and turn the laptop over so that the spine is facing away from you.
  2. Toshiba Satellite P755 S5390 Touchpad Repair: step 2, image 1 of 2 Toshiba Satellite P755 S5390 Touchpad Repair: step 2, image 2 of 2
    • Slide and hold the locks on both sides of the battery to the unlocked position.
    • Slide and lift the battery out of its compartment.
  3. Toshiba Satellite P755 S5390 Touchpad Repair: step 3, image 1 of 1
    • Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
    • Keep track of these screws, you will need them in reassembly.
  4. Toshiba Satellite P755 S5390 Touchpad Repair: step 4, image 1 of 1
    • Turn the laptop back over.
    • Open the cover.
  5. Toshiba Satellite P755 S5390 Touchpad Repair: step 5, image 1 of 3 Toshiba Satellite P755 S5390 Touchpad Repair: step 5, image 2 of 3 Toshiba Satellite P755 S5390 Touchpad Repair: step 5, image 3 of 3
    • Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
    • Do not touch the motherboard.
  6. Toshiba Satellite P755 S5390 Touchpad Repair: step 6, image 1 of 2 Toshiba Satellite P755 S5390 Touchpad Repair: step 6, image 2 of 2
    • Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
  7. Toshiba Satellite P755 S5390 Touchpad Repair: step 7, image 1 of 3 Toshiba Satellite P755 S5390 Touchpad Repair: step 7, image 2 of 3 Toshiba Satellite P755 S5390 Touchpad Repair: step 7, image 3 of 3
5 other people completed this guide.
Dominic Oldani
237 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 31
All Time: 6,664
