Toshiba Satellite P75-A7100 Fan Replacement
  1. Toshiba Satellite P75-A7100 Fan Replacement, Battery: step 1, image 1 of 1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Fan Replacement: step 2, image 1 of 2 Toshiba Satellite P75-A7100 Fan Replacement: step 2, image 2 of 2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: step 3, image 1 of 2 Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Fan Replacement: step 4, image 1 of 3 Toshiba Satellite P75-A7100 Fan Replacement: step 4, image 2 of 3 Toshiba Satellite P75-A7100 Fan Replacement: step 4, image 3 of 3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Fan Replacement: step 5, image 1 of 2 Toshiba Satellite P75-A7100 Fan Replacement: step 5, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Fan Replacement: step 6, image 1 of 3 Toshiba Satellite P75-A7100 Fan Replacement: step 6, image 2 of 3 Toshiba Satellite P75-A7100 Fan Replacement: step 6, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Toshiba Satellite P75-A7100 Fan Replacement, Fan: step 7, image 1 of 2 Toshiba Satellite P75-A7100 Fan Replacement, Fan: step 7, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
2 other people completed this guide.
One Comment
How do you remove and replace the fan from from/to the heatsink? Mine is secured with a metallic tape that is not sticky once removed.
Bruce - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 23
All Time: 2,271
