Toshiba Satellite P75-A7100 Display Screen Replacement
  1. Toshiba Satellite P75-A7100 Display Screen Replacement, Display Screen: step 1, image 1 of 2 Toshiba Satellite P75-A7100 Display Screen Replacement, Display Screen: step 1, image 2 of 2
    • Open the laptop and unscrew each of the screws that are in the corners of the screen using a Phillips #1 screwdriver.
  2. Toshiba Satellite P75-A7100 Display Screen Replacement: step 2, image 1 of 3 Toshiba Satellite P75-A7100 Display Screen Replacement: step 2, image 2 of 3 Toshiba Satellite P75-A7100 Display Screen Replacement: step 2, image 3 of 3
    • Using a metal spudger, insert the spudger around the edges and the bottom to detach the frame from the screen.
  3. Toshiba Satellite P75-A7100 Display Screen Replacement: step 3, image 1 of 1
    • Remove the frame from the device.
  4. Toshiba Satellite P75-A7100 Display Screen Replacement: step 4, image 1 of 3 Toshiba Satellite P75-A7100 Display Screen Replacement: step 4, image 2 of 3 Toshiba Satellite P75-A7100 Display Screen Replacement: step 4, image 3 of 3
    • Using a Phillips #1 screwdriver, unscrew all of the screws on the sides of the screen.
  5. Toshiba Satellite P75-A7100 Display Screen Replacement: step 5, image 1 of 2 Toshiba Satellite P75-A7100 Display Screen Replacement: step 5, image 2 of 2
    • Disconnect the webcam from the screen and unhook any tape.
  6. Toshiba Satellite P75-A7100 Display Screen Replacement: step 6, image 1 of 1
    • Remove the display from the device and add the new one.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 754
